Query Time: 16.47 ms Query memory: 0.023 MB Memory before query: 1.298 MB Rows returned: 0
SELECT `data`
FROM `josed_session`
WHERE `session_id` = X'6461653133633163623635626635653666376465373533326264373938346632'
| Status | Duration |
| Starting | 0.09 ms |
| Opening tables | 14.16 ms |
| After opening tables | 0.02 ms |
| System lock | 0.00 ms |
| table lock | 0.01 ms |
| Opening tables | 0.03 ms |
| table lock | 0.04 ms |
| closing tables | 0.01 ms |
| init | 0.03 ms |
| Optimizing | 0.06 ms |
| Statistics | 1.73 ms |
| Preparing | 0.01 ms |
| Executing | 0.02 ms |
| Query end | 0.00 ms |
| Commit | 0.00 ms |
| closing tables | 0.00 ms |
| Freeing items | 0.01 ms |
| Updating status | 0.05 ms |
Query Time: 0.36 ms After last query: 7.90 ms Query memory: 0.020 MB Memory before query: 1.375 MB Rows returned: 0
SELECT `session_id`
LIMIT 1
| 1 | SIMPLE | josed_session | const | PRIMARY | PRIMARY | 194 | const | 1 | Using index |
| Status | Duration |
| Starting | 0.07 ms |
| Opening tables | 0.01 ms |
| init | 0.02 ms |
| Optimizing | 0.01 ms |
| Statistics | 0.05 ms |
| Preparing | 0.00 ms |
| Executing | 0.01 ms |
| Commit | 0.00 ms |
| Updating status | 0.03 ms |
| 9 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1740 |
| 8 | JDatabaseDriver->loadResult() | JROOT/libraries/src/Session/MetadataManager.php:74 |
| 7 | Joomla\CMS\Session\MetadataManager->createRecordIfNonExisting() | JROOT/libraries/src/Application/CMSApplication.php:154 |
| 6 | Joomla\CMS\Application\CMSApplication->checkSession() | JROOT/libraries/src/Application/CMSApplication.php:856 |
Query Time: 4.85 ms After last query: 0.13 ms Query memory: 0.004 MB Memory before query: 1.380 MB
INSERT INTO `josed_session`
(`session_id`,`guest`,`time`,`userid`,`username`,`client_id`)
VALUES
(X'6461653133633163623635626635653666376465373533326264373938346632', 1, 1780780041, 0, '', 0)
EXPLAIN not possible on query: INSERT INTO `josed_session`
(`session_id`,`guest`,`time`,`userid`,`username`,`client_id`) VALUES
| Status | Duration |
| Starting | 0.04 ms |
| table lock | 0.00 ms |
| init for update | 0.01 ms |
| Update | 2.14 ms |
| Commit | 2.52 ms |
| 8 | JDatabaseDriverMysqli->execute() | JROOT/libraries/src/Session/MetadataManager.php:116 |
Query Time: 12.68 ms After last query: 18.19 ms Query memory: 0.056 MB Memory before query: 1.420 MB Rows returned: 44
SELECT `extension_id` AS `id`,`element` AS `option`,`params`,`enabled`
FROM `josed_extensions`
WHERE `type` = 'component'
AND `state` = 0
AND `enabled` = 1
| 1 | SIMPLE | josed_extensions | ref | extension | extension | 82 | const | 44 | Using index condition; Using where |
| Status | Duration |
| Opening tables | 7.44 ms |
| After opening tables | 0.03 ms |
| Opening tables | 0.02 ms |
| table lock | 0.05 ms |
| init | 0.04 ms |
| Optimizing | 0.03 ms |
| Statistics | 0.77 ms |
| Preparing | 0.03 ms |
| Executing | 0.00 ms |
| Sending data | 4.00 ms |
| Commit | 0.01 ms |
| Query end | 0.01 ms |
| Updating status | 0.02 ms |
| 12 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1701 |
| 11 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Component/ComponentHelper.php:445 |
| 10 | Joomla\CMS\Component\ComponentHelper::Joomla\CMS\Component\{closure}() | Same as call in the line below. |
| 9 | call_user_func_array() | JROOT/libraries/src/Cache/Controller/CallbackController.php:173 |
| 8 | Joomla\CMS\Cache\Controller\CallbackController->get() | JROOT/libraries/src/Component/ComponentHelper.php:453 |
| 7 | Joomla\CMS\Component\ComponentHelper::load() | JROOT/libraries/src/Component/ComponentHelper.php:519 |
| 6 | Joomla\CMS\Component\ComponentHelper::getComponents() | JROOT/libraries/src/Component/ComponentHelper.php:44 |
| 5 | Joomla\CMS\Component\ComponentHelper::getComponent() | JROOT/libraries/src/Component/ComponentHelper.php:103 |
| 4 | Joomla\CMS\Component\ComponentHelper::getParams() | JROOT/libraries/src/Application/SiteApplication.php:594 |
Query Time: 6.02 ms After last query: 10.77 ms Query memory: 0.021 MB Memory before query: 1.529 MB Rows returned: 5
SELECT id, rules
FROM `josed_viewlevels`
| Status | Duration |
| Starting | 0.10 ms |
| Opening tables | 5.52 ms |
| table lock | 0.03 ms |
| init | 0.02 ms |
| Statistics | 0.02 ms |
| Preparing | 0.02 ms |
| Sending data | 0.03 ms |
| Commit | 0.00 ms |
Query Time: 3.22 ms After last query: 0.16 ms Query memory: 0.021 MB Memory before query: 1.541 MB Rows returned: 2
SELECT b.id
FROM josed_usergroups AS a
ON b.lft <= a.lft
AND b.rgt >= a.rgt
WHERE a.id = 9
| Status | Duration |
| Starting | 0.06 ms |
| Opening tables | 2.04 ms |
| table lock | 0.02 ms |
| init | 0.02 ms |
| Optimizing | 0.02 ms |
| Preparing | 0.04 ms |
| Commit | 0.00 ms |
| Updating status | 0.04 ms |
Query Time: 3.48 ms After last query: 6.54 ms Query memory: 0.030 MB Memory before query: 1.567 MB Rows returned: 95
SELECT `folder` AS `type`,`element` AS `name`,`params` AS `params`,`extension_id` AS `id`
FROM josed_extensions
WHERE enabled = 1
AND type = 'plugin'
AND state IN (0,1)
AND access IN (1,1,5)
ORDER BY ordering
| 1 | SIMPLE | josed_extensions | ALL | extension | NO INDEX KEY COULD BE USED | NULL | NULL | 240 | Using where; Using filesort |
| Status | Duration |
| Starting | 0.08 ms |
| init | 0.06 ms |
| Statistics | 0.07 ms |
| Sorting result | 0.01 ms |
| Sending data | 0.01 ms |
| Creating sort index | 2.98 ms |
| Commit | 0.00 ms |
| Freeing items | 0.02 ms |
| 11 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1701 |
| 10 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Plugin/PluginHelper.php:351 |
| 9 | Joomla\CMS\Plugin\PluginHelper::Joomla\CMS\Plugin\{closure}() | Same as call in the line below. |
| 8 | call_user_func_array() | JROOT/libraries/src/Cache/Controller/CallbackController.php:173 |
| 7 | Joomla\CMS\Cache\Controller\CallbackController->get() | JROOT/libraries/src/Plugin/PluginHelper.php:356 |
Query Time: 9.91 ms After last query: 84.06 ms Query memory: 0.022 MB Memory before query: 2.117 MB Rows returned: 1
SELECT `value`
WHERE `key` = 'cparams'
| Status | Duration |
| Starting | 0.18 ms |
| Opening tables | 9.11 ms |
| System lock | 0.01 ms |
| init | 0.04 ms |
| Sending data | 0.02 ms |
| Commit | 0.01 ms |
| closing tables | 0.03 ms |
| Updating status | 0.06 ms |
Query Time: 2.98 ms After last query: 3.61 ms Query memory: 0.021 MB Memory before query: 2.126 MB Rows returned: 0
SELECT *
| Status | Duration |
| Opening tables | 2.56 ms |
| init | 0.02 ms |
| Commit | 0.00 ms |
Query Time: 3.02 ms After last query: 97.50 ms Query memory: 0.021 MB Memory before query: 2.463 MB Rows returned: 0
WHERE ((`dest` = '2-uncategorised') OR (`dest` = '2-uncategorised') OR ('2-uncategorised' LIKE `dest`))
AND `published` = '1'
ORDER BY `ordering` DESC
LIMIT 1
| Status | Duration |
| Opening tables | 2.45 ms |
| Opening tables | 0.04 ms |
| closing tables | 0.02 ms |
| init | 0.04 ms |
| Statistics | 0.03 ms |
| Commit | 0.00 ms |
Query Time: 5.89 ms After last query: 26.97 ms Query memory: 0.023 MB Memory before query: 2.763 MB Rows returned: 34
SELECT *
FROM josed_rsform_config
| Status | Duration |
| Starting | 0.05 ms |
| Opening tables | 4.62 ms |
| init | 0.02 ms |
| Statistics | 0.01 ms |
| Sending data | 0.84 ms |
| Query end | 0.02 ms |
Query Time: 0.29 ms After last query: 0.15 ms Query memory: 0.005 MB Memory before query: 2.775 MB
UPDATE josed_rsform_config
SET `SettingValue`='1780780041'
WHERE `SettingName`='deleteafter.last_run'
EXPLAIN not possible on query: UPDATE josed_rsform_config
| Status | Duration |
| init for update | 0.05 ms |
| Updating | 0.06 ms |
| Freeing items | 0.00 ms |
| 10 | JDatabaseDriverMysqli->execute() | JROOT/administrator/components/com_rsform/helpers/config.php:90 |
| 9 | RSFormProConfig->set() | JROOT/plugins/system/rsformdeletesubmissions/rsformdeletesubmissions.php:35 |
Query Time: 3.57 ms After last query: 0.04 ms Query memory: 0.020 MB Memory before query: 2.779 MB Rows returned: 0
SELECT `FormId`,`DeleteSubmissionsAfter`
FROM `josed_rsform_forms`
WHERE `DeleteSubmissionsAfter` > '0'
| 1 | SIMPLE | NULL | NULL | NULL | NO INDEX KEY COULD BE USED | NULL | NULL | NULL | Impossible WHERE noticed after reading const tables |
| Status | Duration |
| Starting | 0.02 ms |
| Opening tables | 2.43 ms |
| table lock | 0.12 ms |
| init | 0.02 ms |
| Statistics | 0.78 ms |
| 10 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1701 |
| 9 | JDatabaseDriver->loadObjectList() | JROOT/plugins/system/rsformdeletesubmissions/rsformdeletesubmissions.php:45 |
Query Time: 7.84 ms After last query: 14.11 ms Query memory: 0.044 MB Memory before query: 2.877 MB Rows returned: 13
SELECT m.id, m.menutype, m.title, m.alias, m.note, m.path AS route, m.link, m.type, m.level, m.language,`m`.`browserNav`, m.access, m.params, m.home, m.img, m.template_style_id, m.component_id, m.parent_id,e.element as component
FROM josed_menu AS m
LEFT JOIN josed_extensions AS e
ON m.component_id = e.extension_id
WHERE m.published = 1
AND m.parent_id > 0
AND m.client_id = 0
ORDER BY m.lft
| 1 | SIMPLE | m | ref | idx_client_id_parent_id_alias_language | idx_client_id_parent_id_alias_language | 1 | const | 33 | Using index condition; Using where; Using filesort |
| 1 | SIMPLE | e | eq_ref | PRIMARY | PRIMARY | 4 | becws_dbase3.m.component_id | 1 | Using where |
| Status | Duration |
| Opening tables | 4.35 ms |
| table lock | 0.09 ms |
| init | 0.03 ms |
| Statistics | 0.54 ms |
| Creating sort index | 2.42 ms |
| Commit | 0.00 ms |
| 19 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1701 |
| 18 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Menu/SiteMenu.php:93 |
| 17 | Joomla\CMS\Menu\SiteMenu->Joomla\CMS\Menu\{closure}() | Same as call in the line below. |
| 16 | call_user_func_array() | JROOT/libraries/src/Cache/Controller/CallbackController.php:173 |
| 15 | Joomla\CMS\Cache\Controller\CallbackController->get() | JROOT/libraries/src/Menu/SiteMenu.php:101 |
| 14 | Joomla\CMS\Menu\SiteMenu->load() | JROOT/libraries/src/Menu/AbstractMenu.php:78 |
| 13 | Joomla\CMS\Menu\AbstractMenu->__construct() | JROOT/libraries/src/Menu/SiteMenu.php:62 |
| 12 | Joomla\CMS\Menu\SiteMenu->__construct() | JROOT/libraries/src/Menu/AbstractMenu.php:142 |
| 11 | Joomla\CMS\Menu\AbstractMenu::getInstance() | JROOT/libraries/src/Application/CMSApplication.php:445 |
| 10 | Joomla\CMS\Application\CMSApplication->getMenu() | JROOT/libraries/src/Application/SiteApplication.php:275 |
| 9 | Joomla\CMS\Application\SiteApplication->getMenu() | JROOT/libraries/src/Router/SiteRouter.php:65 |
| 8 | Joomla\CMS\Router\SiteRouter->__construct() | JROOT/libraries/src/Router/Router.php:189 |
| 7 | Joomla\CMS\Router\Router::getInstance() | JROOT/libraries/src/Application/CMSApplication.php:561 |
| 6 | Joomla\CMS\Application\CMSApplication::getRouter() | JROOT/libraries/src/Application/SiteApplication.php:403 |
| 5 | Joomla\CMS\Application\SiteApplication::getRouter() | JROOT/libraries/src/Application/CMSApplication.php:1169 |
| 4 | Joomla\CMS\Application\CMSApplication->route() | JROOT/libraries/src/Application/SiteApplication.php:796 |
| 3 | Joomla\CMS\Application\SiteApplication->route() | JROOT/libraries/src/Application/SiteApplication.php:218 |
Query Time: 6.80 ms After last query: 49.27 ms Query memory: 0.023 MB Memory before query: 3.079 MB Rows returned: 2
ON (s.lft <= c.lft
AND s.rgt < c.rgt)
AND c.access IN (1,1,5)
AND c.published = 1
AND s.id = 2
ORDER BY c.lft
| 1 | SIMPLE | c | range|filter | cat_idx,idx_access,idx_left_right | idx_left_right|cat_idx | 4|207 | NULL | 2 (58%) | Using index condition; Using where; Using rowid filter |
| Status | Duration |
| Starting | 0.22 ms |
| Opening tables | 4.23 ms |
| table lock | 0.07 ms |
| init | 0.07 ms |
| Statistics | 1.72 ms |
| Sending data | 0.11 ms |
| Commit | 0.00 ms |
| 13 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Categories/Categories.php:324 |
| 12 | Joomla\CMS\Categories\Categories->_load() | JROOT/libraries/src/Categories/Categories.php:184 |
| 11 | Joomla\CMS\Categories\Categories->get() | JROOT/components/com_content/helpers/legacyrouter.php:350 |
| 10 | ContentRouterRulesLegacy->parse() | JROOT/libraries/src/Component/Router/RouterView.php:266 |
| 9 | Joomla\CMS\Component\Router\RouterView->parse() | JROOT/libraries/src/Router/SiteRouter.php:438 |
| 8 | Joomla\CMS\Router\SiteRouter->parseSefRoute() | JROOT/libraries/src/Router/Router.php:482 |
| 7 | Joomla\CMS\Router\Router->_parseSefRoute() | JROOT/libraries/src/Router/Router.php:227 |
| 6 | Joomla\CMS\Router\Router->parse() | JROOT/libraries/src/Router/SiteRouter.php:139 |
| 5 | Joomla\CMS\Router\SiteRouter->parse() | JROOT/libraries/src/Application/CMSApplication.php:1170 |
Query Time: 1.71 ms After last query: 4.95 ms Query memory: 0.022 MB Memory before query: 3.124 MB Rows returned: 1
WHERE `type` = 'library'
AND `element` = 'joomla'
| 1 | SIMPLE | josed_extensions | ref | element_clientid,element_folder_clientid,extension | extension | 484 | const,const | 1 | Using index condition |
| Status | Duration |
| init | 0.02 ms |
| Statistics | 1.40 ms |
| Commit | 0.00 ms |
| 15 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1662 |
| 14 | JDatabaseDriver->loadObject() | JROOT/libraries/src/Helper/LibraryHelper.php:167 |
| 13 | Joomla\CMS\Helper\LibraryHelper::Joomla\CMS\Helper\{closure}() | Same as call in the line below. |
| 12 | call_user_func_array() | JROOT/libraries/src/Cache/Controller/CallbackController.php:173 |
| 11 | Joomla\CMS\Cache\Controller\CallbackController->get() | JROOT/libraries/src/Helper/LibraryHelper.php:175 |
| 10 | Joomla\CMS\Helper\LibraryHelper::loadLibrary() | JROOT/libraries/src/Helper/LibraryHelper.php:43 |
| 9 | Joomla\CMS\Helper\LibraryHelper::getLibrary() | JROOT/libraries/src/Helper/LibraryHelper.php:90 |
| 8 | Joomla\CMS\Helper\LibraryHelper::getParams() | JROOT/libraries/src/Version.php:321 |
Query Time: 2.08 ms After last query: 0.29 ms Query memory: 0.005 MB Memory before query: 3.115 MB
UPDATE `josed_extensions`
SET `params` = '{\"mediaversion\":\"8fbd923c1a7e8fc1c0c6f947eacdfacc\"}'
| Status | Duration |
| Starting | 0.03 ms |
| init for update | 0.03 ms |
| Updating | 0.07 ms |
| Commit | 1.82 ms |
Query Time: 2.83 ms After last query: 7.29 ms Query memory: 0.019 MB Memory before query: 3.212 MB Rows returned: 1
SELECT *
FROM josed_languages
WHERE published=1
ORDER BY ordering ASC
| 1 | SIMPLE | josed_languages | ALL | NULL | NO INDEX KEY COULD BE USED | NULL | NULL | 1 | Using where; Using filesort |
| Status | Duration |
| Opening tables | 2.40 ms |
| init | 0.02 ms |
| Creating sort index | 0.04 ms |
| Commit | 0.00 ms |
| 7 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1701 |
| 6 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Language/LanguageHelper.php:150 |
| 5 | Joomla\CMS\Language\LanguageHelper::getLanguages() | JROOT/libraries/src/Application/SiteApplication.php:330 |
| 4 | Joomla\CMS\Application\SiteApplication->getParams() | JROOT/libraries/src/Application/SiteApplication.php:138 |
Query Time: 3.44 ms After last query: 1.17 ms Query memory: 0.019 MB Memory before query: 3.227 MB Rows returned: 9
SELECT id, home, template, s.params
FROM josed_template_styles as s
LEFT JOIN josed_extensions as e
ON e.element=s.template
AND e.type='template'
AND e.client_id=s.client_id
WHERE s.client_id = 0
AND e.enabled = 1
| 1 | SIMPLE | s | ALL | idx_template,idx_client_id,idx_client_id_home | NO INDEX KEY COULD BE USED | NULL | NULL | 10 | Using where |
| 1 | SIMPLE | e | ref | element_clientid,element_folder_clientid,extension | element_clientid | 403 | becws_dbase3.s.template,const | 1 | Using index condition; Using where |
| Status | Duration |
| Opening tables | 1.54 ms |
| init | 0.02 ms |
| Statistics | 1.47 ms |
| Sending data | 0.08 ms |
| Commit | 0.00 ms |
| 6 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1701 |
| 5 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Application/SiteApplication.php:486 |
| 4 | Joomla\CMS\Application\SiteApplication->getTemplate() | JROOT/libraries/src/Application/SiteApplication.php:168 |
Query Time: 5.48 ms After last query: 31.96 ms Query memory: 0.029 MB Memory before query: 3.408 MB Rows returned: 44
FROM `josed_assets`
| Status | Duration |
| Starting | 0.12 ms |
| Opening tables | 3.44 ms |
| init | 0.06 ms |
| Statistics | 0.12 ms |
| Sending data | 1.25 ms |
| Commit | 0.00 ms |
| 21 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1701 |
| 20 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Access/Access.php:429 |
| 19 | Joomla\CMS\Access\Access::preloadComponents() | JROOT/libraries/src/Access/Access.php:213 |
| 18 | Joomla\CMS\Access\Access::preload() | JROOT/libraries/src/Access/Access.php:531 |
| 17 | Joomla\CMS\Access\Access::getAssetRules() | JROOT/libraries/src/Access/Access.php:183 |
| 16 | Joomla\CMS\Access\Access::check() | JROOT/libraries/src/User/User.php:398 |
| 15 | Joomla\CMS\User\User->authorise() | JROOT/components/com_content/models/category.php:139 |
| 14 | ContentModelCategory->populateState() | JROOT/libraries/src/MVC/Model/BaseDatabaseModel.php:457 |
| 13 | Joomla\CMS\MVC\Model\BaseDatabaseModel->getState() | JROOT/libraries/src/MVC/View/CategoryView.php:116 |
| 12 | Joomla\CMS\MVC\View\CategoryView->commonCategoryDisplay() | JROOT/components/com_content/views/category/view.html.php:75 |
| 11 | ContentViewCategory->display() | JROOT/libraries/src/Cache/Controller/ViewController.php:102 |
Query Time: 1.94 ms After last query: 0.25 ms Query memory: 0.029 MB Memory before query: 3.469 MB Rows returned: 44
FROM `josed_assets`
| Status | Duration |
| init | 0.03 ms |
| Statistics | 1.17 ms |
| Sending data | 0.10 ms |
| Commit | 0.00 ms |
| 20 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Access/Access.php:359 |
| 19 | Joomla\CMS\Access\Access::preloadPermissions() | JROOT/libraries/src/Access/Access.php:226 |
| 18 | Joomla\CMS\Access\Access::preload() | JROOT/libraries/src/Access/Access.php:540 |
Query Time: 8.17 ms After last query: 2.29 ms Query memory: 0.025 MB Memory before query: 3.520 MB Rows returned: 2
CASE WHEN CHAR_LENGTH(c.alias) != 0 THEN CONCAT_WS(':', c.id, c.alias) ELSE c.id END as slug,(
SELECT COUNT(i.`id`)
FROM `josed_content` AS `i`
WHERE i.`catid` = c.id
AND i.state = 1) AS numitems
ON (s.lft <= c.lft
AND s.rgt < c.rgt)
AND c.published = 1
AND s.id = 2
ORDER BY c.lft
| 1 | PRIMARY | s | const | PRIMARY,idx_left_right | PRIMARY | 4 | const | 1 | |
| 1 | PRIMARY | c | range|filter | cat_idx,idx_left_right | idx_left_right|cat_idx | 4|203 | NULL | 2 (42%) | Using index condition; Using where; Using rowid filter |
| 2 | DEPENDENT SUBQUERY | i | ref | idx_state,idx_catid | idx_catid | 4 | becws_dbase3.c.id | 4 | Using index condition; Using where |
| Status | Duration |
| Opening tables | 2.59 ms |
| table lock | 0.08 ms |
| init | 0.06 ms |
| Statistics | 0.15 ms |
| Statistics | 0.56 ms |
| Sending data | 0.12 ms |
| Sending data | 0.53 ms |
| Sending data | 3.53 ms |
| Commit | 0.00 ms |
| Removing tmp table | 0.01 ms |
| 17 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Categories/Categories.php:324 |
| 16 | Joomla\CMS\Categories\Categories->_load() | JROOT/libraries/src/Categories/Categories.php:184 |
| 15 | Joomla\CMS\Categories\Categories->get() | JROOT/components/com_content/models/category.php:355 |
| 14 | ContentModelCategory->getCategory() | JROOT/libraries/src/MVC/View/HtmlView.php:425 |
| 13 | Joomla\CMS\MVC\View\HtmlView->get() | JROOT/libraries/src/MVC/View/CategoryView.php:122 |
Query Time: 5.79 ms After last query: 5.03 ms Query memory: 0.028 MB Memory before query: 3.554 MB Rows returned: 3
SELECT a.id, a.title, a.alias, a.introtext, a.fulltext, a.checked_out, a.checked_out_time, a.catid, a.created, a.created_by, a.created_by_alias,
CASE WHEN c.published = 2
AND a.state > 0 THEN 2 WHEN c.published != 1 THEN 0 ELSE a.state END as state,
CASE WHEN a.modified = '0000-00-00 00:00:00' THEN a.created ELSE a.modified END as modified, a.modified_by, uam.name as modified_by_name,
CASE WHEN a.publish_up = '0000-00-00 00:00:00' THEN a.created ELSE a.publish_up END as publish_up,a.publish_down, a.images, a.urls, a.attribs, a.metadata, a.metakey, a.metadesc, a.access, a.hits, a.xreference, a.featured, a.language, LENGTH(a.fulltext) AS readmore, a.ordering,c.title AS category_title, c.path AS category_route, c.access AS category_access, c.alias AS category_alias,c.published, c.published AS parents_published, c.lft,
CASE WHEN a.created_by_alias > ' ' THEN a.created_by_alias ELSE ua.name END AS author,ua.email AS author_email,parent.title as parent_title, parent.id as parent_id, parent.path as parent_route, parent.alias as parent_alias,COALESCE(NULLIF(ROUND(v.rating_sum / v.rating_count, 0), 0), 0) AS rating,
COALESCE(NULLIF(v.rating_count, 0), 0) as rating_count
FROM josed_content AS a
LEFT JOIN josed_categories AS c
ON c.id = a.catid
LEFT JOIN josed_users AS ua
ON ua.id = a.created_by
LEFT JOIN josed_users AS uam
ON uam.id = a.modified_by
ON parent.id = c.parent_id
ON a.id = v.content_id
WHERE a.access IN (1,1,5)
AND c.published = 1
AND a.state = 1
AND a.catid = 2
AND (a.publish_up = '0000-00-00 00:00:00' OR a.publish_up <= '2026-06-06 21:07:21')
AND (a.publish_down = '0000-00-00 00:00:00' OR a.publish_down >= '2026-06-06 21:07:21')
ORDER BY c.lft,
CASE WHEN a.publish_up = '0000-00-00 00:00:00' THEN a.created ELSE a.publish_up END DESC , a.created
LIMIT 3
| 1 | SIMPLE | c | const | PRIMARY,idx_access | PRIMARY | 4 | const | 1 | |
| 1 | SIMPLE | a | index_merge | idx_access,idx_state,idx_catid | idx_state,idx_catid | 1,4 | NULL | 11 | Using intersect(idx_state,idx_catid); Using where; Using filesort |
| 1 | SIMPLE | ua | eq_ref | PRIMARY | PRIMARY | 4 | becws_dbase3.a.created_by | 1 | Using where |
| 1 | SIMPLE | uam | eq_ref | PRIMARY | PRIMARY | 4 | becws_dbase3.a.modified_by | 1 | Using where |
| 1 | SIMPLE | parent | eq_ref | PRIMARY | PRIMARY | 4 | const | 1 | Using where |
| 1 | SIMPLE | v | eq_ref | PRIMARY | PRIMARY | 4 | becws_dbase3.a.id | 1 | Using where |
| Status | Duration |
| Starting | 0.17 ms |
| Opening tables | 4.04 ms |
| init | 0.09 ms |
| Optimizing | 0.04 ms |
| Statistics | 0.74 ms |
| Preparing | 0.05 ms |
| Creating sort index | 0.33 ms |
| Commit | 0.00 ms |
| 18 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/MVC/Model/BaseDatabaseModel.php:322 |
| 17 | Joomla\CMS\MVC\Model\BaseDatabaseModel->_getList() | JROOT/libraries/src/MVC/Model/ListModel.php:194 |
| 16 | Joomla\CMS\MVC\Model\ListModel->getItems() | JROOT/components/com_content/models/articles.php:576 |
| 15 | ContentModelArticles->getItems() | JROOT/components/com_content/models/category.php:253 |
| 14 | ContentModelCategory->getItems() | JROOT/libraries/src/MVC/View/HtmlView.php:425 |
| 13 | Joomla\CMS\MVC\View\HtmlView->get() | JROOT/libraries/src/MVC/View/CategoryView.php:144 |
Query Time: 0.63 ms After last query: 2.85 ms Query memory: 0.025 MB Memory before query: 3.626 MB Rows returned: 1
SELECT COUNT(*)
ON c.id = a.catid
AND c.published = 1
AND a.state = 1
AND a.catid = 2
| 1 | SIMPLE | a | index_merge | idx_access,idx_state,idx_catid | idx_state,idx_catid | 1,4 | NULL | 11 | Using intersect(idx_state,idx_catid); Using where |
| Status | Duration |
| init | 0.03 ms |
| Statistics | 0.06 ms |
| Sending data | 0.22 ms |
| Commit | 0.00 ms |
| 19 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1740 |
| 18 | JDatabaseDriver->loadResult() | JROOT/libraries/src/MVC/Model/BaseDatabaseModel.php:354 |
| 17 | Joomla\CMS\MVC\Model\BaseDatabaseModel->_getListCount() | JROOT/libraries/src/MVC/Model/ListModel.php:289 |
| 16 | Joomla\CMS\MVC\Model\ListModel->getTotal() | JROOT/libraries/src/MVC/Model/ListModel.php:239 |
| 15 | Joomla\CMS\MVC\Model\ListModel->getPagination() | JROOT/components/com_content/models/category.php:265 |
Query Time: 5.91 ms After last query: 7.12 ms Query memory: 0.023 MB Memory before query: 3.698 MB Rows returned: 0
SELECT `m`.`tag_id`,`t`.*
INNER JOIN `josed_tags` AS t
ON `m`.`tag_id` = `t`.`id`
WHERE `m`.`type_alias` = 'com_content.category'
AND `m`.`content_item_id` = 2
AND `t`.`published` = 1
AND t.access IN (1,1,5)
| Status | Duration |
| Opening tables | 4.16 ms |
| init | 0.03 ms |
| Statistics | 1.11 ms |
| Commit | 0.00 ms |
| 15 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1701 |
| 14 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Helper/TagsHelper.php:454 |
| 13 | Joomla\CMS\Helper\TagsHelper->getItemTags() | JROOT/libraries/src/MVC/View/CategoryView.php:229 |
Query Time: 8.28 ms After last query: 37.27 ms Query memory: 0.025 MB Memory before query: 3.746 MB Rows returned: 0
FROM josed_fields AS a
ON l.lang_code = a.language
LEFT JOIN josed_users AS uc
ON uc.id=a.checked_out
ON ag.id = a.access
ON ua.id = a.created_user_id
ON g.id = a.group_id
ON fc.field_id = a.id
AND (fc.category_id IS NULL OR fc.category_id IN (2,0))
AND a.access IN (1,1,5)
AND a.state = 1
ORDER BY a.ordering ASC
| Status | Duration |
| Starting | 0.14 ms |
| Opening tables | 5.63 ms |
| table lock | 0.06 ms |
| init | 0.06 ms |
| Statistics | 1.57 ms |
| Creating tmp table | 0.06 ms |
| Sorting result | 0.02 ms |
| Sending data | 0.28 ms |
| Removing tmp table | 0.05 ms |
| Commit | 0.00 ms |
| 12 | JEventDispatcher->trigger() | JROOT/components/com_content/views/category/view.html.php:113 |
Query Time: 3.02 ms After last query: 12.87 ms Query memory: 0.024 MB Memory before query: 3.837 MB Rows returned: 1
SELECT option_value
LIMIT 1
| Status | Duration |
| Opening tables | 2.11 ms |
| init | 0.03 ms |
| Statistics | 0.48 ms |
Query Time: 0.19 ms After last query: 0.08 ms Query memory: 0.024 MB Memory before query: 3.845 MB Rows returned: 1
SELECT option_value
LIMIT 1
| Status | Duration |
| init | 0.01 ms |
Query Time: 0.13 ms After last query: 0.27 ms Query memory: 0.024 MB Memory before query: 3.854 MB Rows returned: 1
SELECT option_value
LIMIT 1
| Status | Duration |
| Starting | 0.01 ms |
| Opening tables | 0.00 ms |
| init | 0.01 ms |
| Optimizing | 0.00 ms |
| Sending data | 0.00 ms |
| Updating status | 0.01 ms |
Query Time: 0.12 ms After last query: 0.03 ms Query memory: 0.024 MB Memory before query: 3.862 MB Rows returned: 1
SELECT option_value
LIMIT 1
| Status | Duration |
| init | 0.01 ms |
Query Time: 0.12 ms After last query: 0.13 ms Query memory: 0.024 MB Memory before query: 3.871 MB Rows returned: 1
SELECT option_value
LIMIT 1
| Status | Duration |
| init | 0.01 ms |
Query Time: 0.11 ms After last query: 0.03 ms Query memory: 0.024 MB Memory before query: 3.879 MB Rows returned: 1
SELECT option_value
LIMIT 1
| Status | Duration |
| init | 0.01 ms |
Query Time: 1.18 ms After last query: 25.30 ms Query memory: 0.028 MB Memory before query: 3.992 MB Rows returned: 0
ON ag.id = a.access
WHERE a.context = 'com_content.categories'
AND a.state = 1
| Status | Duration |
| Starting | 0.16 ms |
| Opening tables | 0.05 ms |
| init | 0.06 ms |
| Optimizing | 0.05 ms |
| Creating tmp table | 0.05 ms |
| Sending data | 0.30 ms |
| Commit | 0.00 ms |
| 24 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1701 |
| 23 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/MVC/Model/BaseDatabaseModel.php:322 |
| 22 | Joomla\CMS\MVC\Model\BaseDatabaseModel->_getList() | JROOT/administrator/components/com_fields/models/fields.php:333 |
| 21 | FieldsModelFields->_getList() | JROOT/libraries/src/MVC/Model/ListModel.php:194 |
| 20 | Joomla\CMS\MVC\Model\ListModel->getItems() | JROOT/administrator/components/com_fields/helpers/fields.php:136 |
| 19 | FieldsHelper::getFields() | JROOT/plugins/system/fields/fields.php:495 |
| 18 | PlgSystemFields->onContentPrepare() | JROOT/libraries/joomla/event/event.php:70 |
| 17 | JEvent->update() | JROOT/libraries/joomla/event/dispatcher.php:160 |
| 16 | JEventDispatcher->trigger() | JROOT/components/com_content/views/category/tmpl/blog.php:19 |
| 15 | include JROOT/components/com_content/views/category/tmpl/blog.php | JROOT/libraries/src/MVC/View/HtmlView.php:701 |
| 14 | Joomla\CMS\MVC\View\HtmlView->loadTemplate() | JROOT/libraries/src/MVC/View/HtmlView.php:230 |
| 13 | Joomla\CMS\MVC\View\HtmlView->display() | JROOT/libraries/src/MVC/View/CategoryView.php:245 |
| 12 | Joomla\CMS\MVC\View\CategoryView->display() | JROOT/components/com_content/views/category/view.html.php:250 |
Query Time: 0.22 ms After last query: 0.12 ms Query memory: 0.026 MB Memory before query: 4.005 MB Rows returned: 1
SELECT option_value
LIMIT 1
| Status | Duration |
| init | 0.01 ms |
| 21 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1740 |
| 20 | JDatabaseDriver->loadResult() | JROOT/administrator/components/com_imagerecycle/helpers/imagerecycle.php:172 |
| 19 | ImagerecycleHelper->getOption() | JROOT/plugins/content/imagerecycle/imagerecycle.php:62 |
| 18 | plgContentImagerecycle->onContentPrepare() | JROOT/libraries/joomla/event/event.php:70 |
Query Time: 0.13 ms After last query: 0.03 ms Query memory: 0.026 MB Memory before query: 4.015 MB Rows returned: 1
SELECT option_value
LIMIT 1
| Status | Duration |
| init | 0.01 ms |
| 19 | ImagerecycleHelper->getOption() | JROOT/plugins/content/imagerecycle/imagerecycle.php:63 |
Query Time: 0.76 ms After last query: 0.30 ms Query memory: 0.027 MB Memory before query: 4.027 MB Rows returned: 0
ON ag.id = a.access
AND a.state = 1
| Status | Duration |
| init | 0.04 ms |
| Statistics | 0.08 ms |
| Creating tmp table | 0.04 ms |
| Creating sort index | 0.02 ms |
| Removing tmp table | 0.04 ms |
| Commit | 0.00 ms |
| 25 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1701 |
| 24 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/MVC/Model/BaseDatabaseModel.php:322 |
| 23 | Joomla\CMS\MVC\Model\BaseDatabaseModel->_getList() | JROOT/administrator/components/com_fields/models/fields.php:333 |
| 22 | FieldsModelFields->_getList() | JROOT/libraries/src/MVC/Model/ListModel.php:194 |
| 21 | Joomla\CMS\MVC\Model\ListModel->getItems() | JROOT/administrator/components/com_fields/helpers/fields.php:136 |
| 20 | FieldsHelper::getFields() | JROOT/plugins/system/fields/fields.php:404 |
| 19 | PlgSystemFields->display() | JROOT/plugins/system/fields/fields.php:324 |
| 18 | PlgSystemFields->onContentAfterTitle() | JROOT/libraries/joomla/event/event.php:70 |
| 16 | JEventDispatcher->trigger() | JROOT/components/com_content/views/category/tmpl/blog.php:22 |
Query Time: 6.24 ms After last query: 31.40 ms Query memory: 0.046 MB Memory before query: 4.063 MB Rows returned: 36
SELECT m.id, m.title, m.module, m.position, m.content, m.showtitle, m.params, mm.menuid
FROM josed_modules AS m
LEFT JOIN josed_modules_menu AS mm
ON mm.moduleid = m.id
ON e.element = m.module
AND e.client_id = m.client_id
AND e.enabled = 1
AND (m.publish_up = '0000-00-00 00:00:00' OR m.publish_up <= '2026-06-06 21:07:21')
AND (m.publish_down = '0000-00-00 00:00:00' OR m.publish_down >= '2026-06-06 21:07:21')
AND m.access IN (1,1,5)
AND m.client_id = 0
AND (mm.menuid = 101 OR mm.menuid <= 0)
ORDER BY m.position, m.ordering
| 1 | SIMPLE | m | ref | PRIMARY,published,newsfeeds | published | 1 | const | 44 | Using index condition; Using where; Using filesort |
| 1 | SIMPLE | mm | ref | PRIMARY | PRIMARY | 4 | becws_dbase3.m.id | 1 | Using where; Using index |
| 1 | SIMPLE | e | ref | element_clientid,element_folder_clientid | element_clientid | 403 | becws_dbase3.m.module,const | 1 | Using index condition; Using where |
| Status | Duration |
| Opening tables | 2.91 ms |
| closing tables | 0.05 ms |
| init | 0.05 ms |
| Statistics | 0.58 ms |
| Preparing | 0.08 ms |
| Creating sort index | 2.06 ms |
| Commit | 0.00 ms |
| 13 | JDatabaseDriver->loadObjectList() | Same as call in the line below. |
| 11 | Joomla\CMS\Cache\Controller\CallbackController->get() | JROOT/libraries/src/Helper/ModuleHelper.php:441 |
| 10 | Joomla\CMS\Helper\ModuleHelper::getModuleList() | JROOT/libraries/src/Helper/ModuleHelper.php:371 |
| 9 | Joomla\CMS\Helper\ModuleHelper::load() | JROOT/libraries/src/Helper/ModuleHelper.php:87 |
| 8 | Joomla\CMS\Helper\ModuleHelper::getModules() | JROOT/libraries/src/Document/Renderer/Html/ModulesRenderer.php:45 |
| 7 | Joomla\CMS\Document\Renderer\Html\ModulesRenderer->render() | JROOT/libraries/src/Document/HtmlDocument.php:499 |
Query Time: 6.42 ms After last query: 117.10 ms Query memory: 0.023 MB Memory before query: 4.281 MB Rows returned: 0
FROM josed_bagallery_items
WHERE lightboxUrl = '/2-uncategorised'
| Status | Duration |
| Starting | 0.33 ms |
| Opening tables | 2.76 ms |
| init | 0.04 ms |
| Sending data | 1.84 ms |
| Commit | 0.00 ms |
Query Time: 3.17 ms After last query: 21.80 ms Query memory: 0.033 MB Memory before query: 4.432 MB Rows returned: 15
SELECT `id`,`referencekey`,`value`,`system`,`editable`
FROM `josed_nextend2_section_storage`
WHERE `application` = 'system'
AND `section` = 'global'
| 1 | SIMPLE | josed_nextend2_section_storage | ref | application,application_2 | application_2 | 214 | const,const | 15 | Using index condition; Using where |
| Status | Duration |
| Opening tables | 1.68 ms |
| init | 0.03 ms |
| Optimizing | 0.07 ms |
| Statistics | 0.09 ms |
| Sending data | 0.86 ms |
| 34 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1506 |
| 33 | JDatabaseDriver->loadAssocList() | JROOT/libraries/smartslider3/src/Framework/Database/Joomla/JoomlaConnectorTable.php:95 |
| 32 | Nextend\Framework\Database\Joomla\JoomlaConnectorTable->findAllByAttributes() | JROOT/libraries/smartslider3/src/Framework/Model/Section.php:77 |
| 31 | Nextend\Framework\Model\Section::getAll() | JROOT/libraries/smartslider3/src/Framework/Settings.php:30 |
| 30 | Nextend\Framework\Settings->__construct() | JROOT/libraries/smartslider3/src/Framework/Settings.php:67 |
| 29 | require JROOT/libraries/smartslider3/src/Framework/Settings.php | JROOT/libraries/smartslider3/src/Autoloader.php:194 |
| 28 | Nextend\Autoloader->requireFile() | JROOT/libraries/smartslider3/src/Autoloader.php:175 |
| 27 | Nextend\Autoloader->loadMappedFile() | JROOT/libraries/smartslider3/src/Autoloader.php:128 |
| 26 | Nextend\Autoloader->loadClass() | Same as call in the line below. |
| 25 | spl_autoload_call() | JROOT/libraries/smartslider3/src/Framework/ResourceTranslator/ResourceTranslator.php:26 |
| 24 | Nextend\Framework\ResourceTranslator\ResourceTranslator->init() | JROOT/libraries/smartslider3/src/Framework/Pattern/SingletonTrait.php:16 |
| 23 | Nextend\Framework\ResourceTranslator\ResourceTranslator->__construct() | JROOT/libraries/smartslider3/src/Framework/Pattern/SingletonTrait.php:12 |
| 22 | Nextend\Framework\ResourceTranslator\ResourceTranslator::getInstance() | JROOT/libraries/smartslider3/src/Framework/ResourceTranslator/ResourceTranslator.php:171 |
| 21 | require JROOT/libraries/smartslider3/src/Framework/ResourceTranslator/ResourceTranslator.php | JROOT/libraries/smartslider3/src/Autoloader.php:194 |
| 20 | Nextend\Autoloader->requireFile() | JROOT/libraries/smartslider3/src/Autoloader.php:175 |
| 19 | Nextend\Autoloader->loadMappedFile() | JROOT/libraries/smartslider3/src/Autoloader.php:128 |
| 18 | Nextend\Autoloader->loadClass() | Same as call in the line below. |
| 17 | spl_autoload_call() | JROOT/libraries/smartslider3/src/Framework/Application/AbstractApplicationType.php:47 |
| 16 | Nextend\Framework\Application\AbstractApplicationType->__construct() | JROOT/libraries/smartslider3/src/SmartSlider3/Application/ApplicationSmartSlider3.php:30 |
| 15 | Nextend\SmartSlider3\Application\ApplicationSmartSlider3->init() | JROOT/libraries/smartslider3/src/Framework/Pattern/SingletonTrait.php:16 |
| 14 | Nextend\Framework\Application\AbstractApplication->__construct() | JROOT/libraries/smartslider3/src/Framework/Pattern/SingletonTrait.php:12 |
| 13 | Nextend\Framework\Application\AbstractApplication::getInstance() | JROOT/libraries/smartslider3/src/SmartSlider3/Platform/Joomla/compat.php:7 |
| 12 | nextend_smartslider3() | JROOT/libraries/smartslider3/src/SmartSlider3/Platform/Joomla/Plugin/PluginSmartSlider3.php:148 |
| 11 | Nextend\SmartSlider3\Platform\Joomla\Plugin\PluginSmartSlider3::prepare() | Same as call in the line below. |
| 10 | preg_replace_callback() | JROOT/libraries/smartslider3/src/SmartSlider3/Platform/Joomla/Plugin/PluginSmartSlider3.php:73 |
| 9 | Nextend\SmartSlider3\Platform\Joomla\Plugin\PluginSmartSlider3->displaySliders() | JROOT/libraries/smartslider3/src/SmartSlider3/Platform/Joomla/Plugin/PluginSmartSlider3.php:102 |
| 8 | Nextend\SmartSlider3\Platform\Joomla\Plugin\PluginSmartSlider3->onNextendBeforeCompileHead() | JROOT/libraries/smartslider3/src/SmartSlider3/Platform/Joomla/Plugin/PluginSmartSlider3.php:114 |
| 7 | Nextend\SmartSlider3\Platform\Joomla\Plugin\PluginSmartSlider3->onAfterRender() | JROOT/libraries/joomla/event/event.php:70 |
| 6 | JEvent->update() | JROOT/libraries/joomla/event/dispatcher.php:160 |
| 5 | JEventDispatcher->trigger() | JROOT/libraries/src/Application/BaseApplication.php:108 |
| 4 | Joomla\CMS\Application\BaseApplication->triggerEvent() | JROOT/libraries/src/Application/CMSApplication.php:1146 |
Query Time: 0.95 ms After last query: 70.04 ms Query memory: 0.029 MB Memory before query: 4.775 MB Rows returned: 0
AND `section` = 'fonts'
| 1 | SIMPLE | josed_nextend2_section_storage | ref | application,application_2 | application_2 | 214 | const,const | 1 | Using index condition; Using where |
| Status | Duration |
| Starting | 0.19 ms |
| init | 0.06 ms |
| Statistics | 0.11 ms |
| End of update loop | 0.03 ms |
| Updating status | 0.09 ms |
| Reset for next command | 0.02 ms |
| 32 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1506 |
| 31 | JDatabaseDriver->loadAssocList() | JROOT/libraries/smartslider3/src/Framework/Database/Joomla/JoomlaConnectorTable.php:95 |
| 30 | Nextend\Framework\Database\Joomla\JoomlaConnectorTable->findAllByAttributes() | JROOT/libraries/smartslider3/src/Framework/Model/Section.php:77 |
| 29 | Nextend\Framework\Model\Section::getAll() | JROOT/libraries/smartslider3/src/Framework/Font/FontSettings.php:82 |
| 28 | Nextend\Framework\Font\FontSettings::load() | JROOT/libraries/smartslider3/src/Framework/Font/FontSettings.php:23 |
| 27 | Nextend\Framework\Font\FontSettings->__construct() | JROOT/libraries/smartslider3/src/Framework/Font/FontSettings.php:138 |
| 26 | require JROOT/libraries/smartslider3/src/Framework/Font/FontSettings.php | JROOT/libraries/smartslider3/src/Autoloader.php:194 |
| 25 | Nextend\Autoloader->requireFile() | JROOT/libraries/smartslider3/src/Autoloader.php:175 |
| 24 | Nextend\Autoloader->loadMappedFile() | JROOT/libraries/smartslider3/src/Autoloader.php:128 |
| 23 | Nextend\Autoloader->loadClass() | Same as call in the line below. |
| 22 | spl_autoload_call() | JROOT/libraries/smartslider3/src/Framework/Font/Sources/GoogleFonts/GoogleFonts.php:93 |
| 21 | Nextend\Framework\Font\Sources\GoogleFonts\GoogleFonts->onFontManagerLoad() | JROOT/libraries/smartslider3/src/Framework/Font/FontSources.php:44 |
| 20 | Nextend\Framework\Font\FontSources::onFontManagerLoad() | JROOT/libraries/smartslider3/src/Framework/Asset/Predefined.php:96 |
| 19 | Nextend\Framework\Asset\Predefined::frontend() | JROOT/libraries/smartslider3/src/Framework/Controller/AbstractController.php:125 |
| 18 | Nextend\Framework\Controller\AbstractController->initialize() | JROOT/libraries/smartslider3/src/Framework/Controller/AbstractController.php:50 |
| 17 | Nextend\Framework\Controller\AbstractController->__construct() | JROOT/libraries/smartslider3/src/SmartSlider3/Application/Frontend/ApplicationTypeFrontend.php:24 |
| 16 | Nextend\SmartSlider3\Application\Frontend\ApplicationTypeFrontend->getControllerSlider() | Same as call in the line below. |
| 15 | call_user_func() | JROOT/libraries/smartslider3/src/Framework/Application/AbstractApplicationType.php:106 |
| 14 | Nextend\Framework\Application\AbstractApplicationType->getController() | JROOT/libraries/smartslider3/src/Framework/Application/AbstractApplicationType.php:86 |
| 13 | Nextend\Framework\Application\AbstractApplicationType->process() | JROOT/libraries/smartslider3/src/SmartSlider3/Platform/Joomla/compat.php:12 |
Query Time: 1.41 ms After last query: 45.76 ms Query memory: 0.027 MB Memory before query: 4.956 MB Rows returned: 1
SELECT *
WHERE `application` = 'cache'
AND `section` = 'notweb/n2-ss-11'
AND `referencekey` = 'variations.manifest'
| 1 | SIMPLE | josed_nextend2_section_storage | ref | application,application_2 | application | 366 | const,const,const | 1 | Using index condition; Using where |
| Status | Duration |
| Starting | 0.11 ms |
| init | 0.04 ms |
| Statistics | 0.14 ms |
| Sending data | 0.75 ms |
| 26 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1465 |
| 25 | JDatabaseDriver->loadAssoc() | JROOT/libraries/smartslider3/src/Framework/Database/Joomla/JoomlaConnectorTable.php:60 |
| 24 | Nextend\Framework\Database\Joomla\JoomlaConnectorTable->findByAttributes() | JROOT/libraries/smartslider3/src/Framework/Model/ApplicationSection.php:44 |
| 23 | Nextend\Framework\Model\ApplicationSection->get() | JROOT/libraries/smartslider3/src/Framework/Cache/Storage/Database.php:32 |
| 22 | Nextend\Framework\Cache\Storage\Database->exists() | JROOT/libraries/smartslider3/src/Framework/Cache/AbstractCache.php:72 |
| 21 | Nextend\Framework\Cache\AbstractCache->exists() | JROOT/libraries/smartslider3/src/SmartSlider3/Slider/Cache/CacheSlider.php:42 |
| 20 | Nextend\SmartSlider3\Slider\Cache\CacheSlider->makeCache() | JROOT/libraries/smartslider3/src/SmartSlider3/SliderManager/SliderManager.php:126 |
| 19 | Nextend\SmartSlider3\SliderManager\SliderManager->cacheSlider() | JROOT/libraries/smartslider3/src/SmartSlider3/SliderManager/SliderManager.php:109 |
| 18 | Nextend\SmartSlider3\SliderManager\SliderManager->render() | JROOT/libraries/smartslider3/src/SmartSlider3/Application/Frontend/Slider/ViewDisplay.php:28 |
| 17 | Nextend\SmartSlider3\Application\Frontend\Slider\ViewDisplay->display() | JROOT/libraries/smartslider3/src/SmartSlider3/Application/Frontend/Slider/ControllerSlider.php:18 |
| 16 | Nextend\SmartSlider3\Application\Frontend\Slider\ControllerSlider->actionDisplay() | Same as call in the line below. |
| 15 | call_user_func_array() | JROOT/libraries/smartslider3/src/Framework/Controller/AbstractController.php:93 |
| 14 | Nextend\Framework\Controller\AbstractController->doAction() | JROOT/libraries/smartslider3/src/Framework/Application/AbstractApplicationType.php:88 |
Query Time: 0.25 ms After last query: 0.11 ms Query memory: 0.027 MB Memory before query: 4.967 MB Rows returned: 1
SELECT *
AND `referencekey` = 'data.manifest'
| Status | Duration |
| init | 0.02 ms |
| 21 | Nextend\Framework\Cache\AbstractCache->exists() | JROOT/libraries/smartslider3/src/SmartSlider3/Slider/Cache/CacheSlider.php:47 |
Query Time: 0.19 ms After last query: 0.06 ms Query memory: 0.028 MB Memory before query: 4.979 MB Rows returned: 1
SELECT *
AND `referencekey` = 'slideren-GB1.manifest'
| Status | Duration |
| init | 0.01 ms |
| 28 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1465 |
| 27 | JDatabaseDriver->loadAssoc() | JROOT/libraries/smartslider3/src/Framework/Database/Joomla/JoomlaConnectorTable.php:60 |
| 26 | Nextend\Framework\Database\Joomla\JoomlaConnectorTable->findByAttributes() | JROOT/libraries/smartslider3/src/Framework/Model/ApplicationSection.php:44 |
| 25 | Nextend\Framework\Model\ApplicationSection->get() | JROOT/libraries/smartslider3/src/Framework/Cache/Storage/Database.php:32 |
| 24 | Nextend\Framework\Cache\Storage\Database->exists() | JROOT/libraries/smartslider3/src/Framework/Cache/AbstractCache.php:72 |
| 23 | Nextend\Framework\Cache\AbstractCache->exists() | JROOT/libraries/smartslider3/src/Framework/Cache/Manifest.php:48 |
| 22 | Nextend\Framework\Cache\Manifest->isCached() | JROOT/libraries/smartslider3/src/Framework/Cache/Manifest.php:28 |
| 21 | Nextend\Framework\Cache\Manifest->makeCache() | JROOT/libraries/smartslider3/src/SmartSlider3/Slider/Cache/CacheSlider.php:54 |
Query Time: 0.36 ms After last query: 3.69 ms Query memory: 0.028 MB Memory before query: 4.994 MB Rows returned: 1
SELECT *
WHERE `application` = 'smartslider'
AND `section` = 'sliderChanged'
AND `referencekey` = 11
| Status | Duration |
| init | 0.02 ms |
| 25 | Nextend\Framework\Model\ApplicationSection->get() | JROOT/libraries/smartslider3/src/SmartSlider3/Application/Helper/HelperSliderChanged.php:36 |
| 24 | Nextend\SmartSlider3\Application\Helper\HelperSliderChanged->isSliderChanged() | JROOT/libraries/smartslider3/src/SmartSlider3/Slider/Cache/CacheSlider.php:114 |
| 23 | Nextend\SmartSlider3\Slider\Cache\CacheSlider->isCacheValid() | JROOT/libraries/smartslider3/src/Framework/Cache/Manifest.php:52 |
Query Time: 1.01 ms After last query: 0.16 ms Query memory: 0.043 MB Memory before query: 5.007 MB Rows returned: 1
SELECT *
AND `referencekey` = 'slideren-GB1'
| Status | Duration |
| init | 0.02 ms |
| Sending data | 0.74 ms |
| 23 | Nextend\Framework\Cache\AbstractCache->exists() | JROOT/libraries/smartslider3/src/Framework/Cache/Manifest.php:52 |
Query Time: 0.32 ms After last query: 1.09 ms Query memory: 0.027 MB Memory before query: 5.063 MB Rows returned: 1
SELECT *
AND `section` = 'settings'
| Status | Duration |
| System lock | 0.00 ms |
| init | 0.02 ms |
| Statistics | 0.04 ms |
| 27 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1465 |
| 26 | JDatabaseDriver->loadAssoc() | JROOT/libraries/smartslider3/src/Framework/Database/Joomla/JoomlaConnectorTable.php:60 |
| 25 | Nextend\Framework\Database\Joomla\JoomlaConnectorTable->findByAttributes() | JROOT/libraries/smartslider3/src/Framework/Model/ApplicationSection.php:44 |
| 24 | Nextend\Framework\Model\ApplicationSection->get() | JROOT/libraries/smartslider3/src/SmartSlider3/Settings.php:17 |
| 23 | Nextend\SmartSlider3\Settings::getAll() | JROOT/libraries/smartslider3/src/SmartSlider3/Settings.php:25 |
| 22 | Nextend\SmartSlider3\Settings::get() | JROOT/libraries/smartslider3/src/SmartSlider3/Platform/Joomla/JoomlaShim.php:56 |
| 21 | Nextend\SmartSlider3\Platform\Joomla\JoomlaShim::triggerOnContentPrepare() | JROOT/libraries/smartslider3/src/SmartSlider3/Slider/Joomla/PlatformSlider.php:28 |
| 20 | Nextend\SmartSlider3\Slider\Joomla\PlatformSlider->addCMSFunctions() | JROOT/libraries/smartslider3/src/SmartSlider3/Slider/Base/PlatformSliderTrait.php:22 |
| 19 | Nextend\SmartSlider3\Slider\Slider->addCMSFunctions() | JROOT/libraries/smartslider3/src/SmartSlider3/SliderManager/SliderManager.php:109 |
Query Time: 0.23 ms After last query: 0.19 ms Query memory: 0.027 MB Memory before query: 5.076 MB Rows returned: 1
SELECT option_value
LIMIT 1
| Status | Duration |
| init | 0.01 ms |
| Preparing | 0.01 ms |
| Query end | 0.00 ms |
| closing tables | 0.00 ms |
| 26 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1740 |
| 25 | JDatabaseDriver->loadResult() | JROOT/administrator/components/com_imagerecycle/helpers/imagerecycle.php:172 |
| 24 | ImagerecycleHelper->getOption() | JROOT/plugins/content/imagerecycle/imagerecycle.php:62 |
| 23 | plgContentImagerecycle->onContentPrepare() | JROOT/libraries/joomla/event/event.php:70 |
| 22 | JEvent->update() | JROOT/libraries/smartslider3/src/SmartSlider3/Platform/Joomla/JoomlaShim.php:87 |
Query Time: 0.13 ms After last query: 0.05 ms Query memory: 0.027 MB Memory before query: 5.087 MB Rows returned: 1
SELECT option_value
LIMIT 1
| Status | Duration |
| init | 0.01 ms |
| 24 | ImagerecycleHelper->getOption() | JROOT/plugins/content/imagerecycle/imagerecycle.php:63 |
10 × SELECT option_value
6 × SELECT *
FROM `josed_assets`
2 × SELECT `extension_id` AS `id`,`element` AS `option`,`params`,`enabled`
2 × SELECT `id`,`referencekey`,`value`,`system`,`editable`
2 × SELECT DISTINCT a.id, a.title, a.name, a.checked_out, a.checked_out_time, a.note, a.state, a.access, a.created_time, a.created_user_id, a.ordering, a.language, a.fieldparams, a.params, a.type, a.default_value, a.context, a.group_id, a.label, a.description, a.required,l.title AS language_title, l.image AS language_image,uc.name AS editor,ag.title AS access_level,ua.name AS author_name,g.title AS group_title, g.access as group_access, g.state AS group_state, g.note as group_note
ON ag.id = a.access
1 × SELECT m.id, m.title, m.module, m.position, m.content, m.showtitle, m.params, mm.menuid
ON ag.id = a.access
1 × SELECT `m`.`tag_id`,`t`.*
1 × SELECT COUNT(*)
ON c.id = a.catid
1 × SELECT a.id, a.title, a.alias, a.introtext, a.fulltext, a.checked_out, a.checked_out_time, a.catid, a.created, a.created_by, a.created_by_alias,
CASE WHEN a.created_by_alias > ' ' THEN a.created_by_alias ELSE ua.name END AS author,ua.email AS author_email,parent.title as parent_title, parent.id as parent_id, parent.path as parent_route, parent.alias as parent_alias,COALESCE(NULLIF(ROUND(v.rating_sum / v.rating_count, 0), 0), 0) AS rating, COALESCE(NULLIF(v.rating_count, 0), 0) as rating_count
ON c.id = a.catid
CASE WHEN CHAR_LENGTH(c.alias) != 0 THEN CONCAT_WS(':', c.id, c.alias) ELSE c.id END as slug,( SELECT COUNT(i.`id`)
1 × SELECT `data`
FROM `josed_session`
1 × SELECT id, home, template, s.params
1 × SELECT `session_id`
ON (s.lft <= c.lft
AND s.rgt < c.rgt)
1 × SELECT m.id, m.menutype, m.title, m.alias, m.note, m.path AS route, m.link, m.type, m.level, m.language,`m`.`browserNav`, m.access, m.params, m.home, m.img, m.template_style_id, m.component_id, m.parent_id,e.element as component
1 × SELECT `FormId`,`DeleteSubmissionsAfter`
1 × SELECT *
1 × SELECT *
1 × SELECT `value`
1 × SELECT `folder` AS `type`,`element` AS `name`,`params` AS `params`,`extension_id` AS `id`
1 × SELECT b.id
ON b.lft <= a.lft
AND b.rgt >= a.rgt
1 × SELECT id, rules
1 × SELECT *
