Query Time: 0.39 ms Query memory: 0.023 MB Memory before query: 1.031 MB Rows returned: 1
SELECT `data`
FROM `josed_session`
WHERE `session_id` = X'3533303565623166316234343038353066643761653866626162616361316531'
| Status | Duration |
| Starting | 0.07 ms |
| Opening tables | 0.02 ms |
| System lock | 0.00 ms |
| table lock | 0.01 ms |
| init | 0.02 ms |
| Optimizing | 0.02 ms |
| Statistics | 0.04 ms |
| Preparing | 0.00 ms |
| Preparing | 0.01 ms |
| Executing | 0.00 ms |
| Sending data | 0.01 ms |
| Query end | 0.00 ms |
| Commit | 0.00 ms |
| closing tables | 0.00 ms |
| closing tables | 0.01 ms |
| Freeing items | 0.01 ms |
| Updating status | 0.03 ms |
Query Time: 0.28 ms After last query: 1.82 ms Query memory: 0.021 MB Memory before query: 1.137 MB Rows returned: 5
SELECT id, rules
FROM `josed_viewlevels`
| Status | Duration |
| Starting | 0.02 ms |
| Opening tables | 0.01 ms |
| init | 0.01 ms |
| Optimizing | 0.01 ms |
| Statistics | 0.01 ms |
| Sending data | 0.03 ms |
| Commit | 0.00 ms |
| Updating status | 0.04 ms |
Query Time: 0.29 ms After last query: 0.08 ms Query memory: 0.021 MB Memory before query: 1.149 MB Rows returned: 2
SELECT b.id
FROM josed_usergroups AS a
ON b.lft <= a.lft
AND b.rgt >= a.rgt
WHERE a.id = 9
| Status | Duration |
| Starting | 0.04 ms |
| table lock | 0.00 ms |
| init | 0.01 ms |
| Statistics | 0.05 ms |
| Preparing | 0.02 ms |
| Sending data | 0.02 ms |
| Commit | 0.00 ms |
| Updating status | 0.02 ms |
Query Time: 0.29 ms After last query: 4.67 ms Query memory: 0.022 MB Memory before query: 1.587 MB Rows returned: 1
SELECT `value`
WHERE `key` = 'cparams'
| Status | Duration |
| Starting | 0.05 ms |
| init | 0.01 ms |
| Statistics | 0.02 ms |
| Commit | 0.00 ms |
Query Time: 0.19 ms After last query: 0.23 ms Query memory: 0.021 MB Memory before query: 1.595 MB Rows returned: 0
SELECT *
| Status | Duration |
| init | 0.01 ms |
| Commit | 0.00 ms |
| Freeing items | 0.00 ms |
Query Time: 0.33 ms After last query: 7.25 ms Query memory: 0.021 MB Memory before query: 1.863 MB Rows returned: 0
WHERE ((`dest` = 'about-us') OR (`dest` = 'about-us') OR ('about-us' LIKE `dest`))
AND `published` = '1'
ORDER BY `ordering` DESC
LIMIT 1
| Status | Duration |
| Starting | 0.06 ms |
| init | 0.03 ms |
| Sorting result | 0.01 ms |
| Commit | 0.00 ms |
Query Time: 0.27 ms After last query: 2.30 ms Query memory: 0.023 MB Memory before query: 2.100 MB Rows returned: 34
SELECT *
FROM josed_rsform_config
| Status | Duration |
| Starting | 0.03 ms |
| System lock | 0.01 ms |
| init | 0.02 ms |
Query Time: 0.32 ms After last query: 3.24 ms Query memory: 0.005 MB Memory before query: 2.335 MB
UPDATE `josed_extensions`
SET `params` = '{\"mediaversion\":\"72507393a87953f23feedc92fd7fabef\"}'
WHERE `type` = 'library'
AND `element` = 'joomla'
| Status | Duration |
| init for update | 0.08 ms |
| Updating | 0.04 ms |
| Commit | 0.01 ms |
| Reset for next command | 0.03 ms |
Query Time: 0.48 ms After last query: 1.84 ms Query memory: 0.028 MB Memory before query: 2.503 MB Rows returned: 44
FROM `josed_assets`
| Status | Duration |
| init | 0.03 ms |
| Statistics | 0.06 ms |
| Sending data | 0.13 ms |
| Commit | 0.00 ms |
| 17 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Access/Access.php:429 |
| 16 | Joomla\CMS\Access\Access::preloadComponents() | JROOT/libraries/src/Access/Access.php:213 |
| 15 | Joomla\CMS\Access\Access::preload() | JROOT/libraries/src/Access/Access.php:531 |
| 14 | Joomla\CMS\Access\Access::getAssetRules() | JROOT/libraries/src/Access/Access.php:183 |
| 13 | Joomla\CMS\Access\Access::check() | JROOT/libraries/src/User/User.php:398 |
| 12 | Joomla\CMS\User\User->authorise() | JROOT/components/com_content/models/article.php:58 |
| 11 | ContentModelArticle->populateState() | JROOT/libraries/src/MVC/Model/BaseDatabaseModel.php:457 |
| 10 | Joomla\CMS\MVC\Model\BaseDatabaseModel->getState() | JROOT/components/com_content/models/article.php:251 |
| 9 | ContentModelArticle->hit() | JROOT/components/com_content/controller.php:113 |
Query Time: 0.30 ms After last query: 0.11 ms Query memory: 0.028 MB Memory before query: 2.562 MB Rows returned: 44
FROM `josed_assets`
| Status | Duration |
| init | 0.01 ms |
| Statistics | 0.03 ms |
| Sending data | 0.07 ms |
| Commit | 0.00 ms |
| 17 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Access/Access.php:359 |
| 16 | Joomla\CMS\Access\Access::preloadPermissions() | JROOT/libraries/src/Access/Access.php:226 |
| 15 | Joomla\CMS\Access\Access::preload() | JROOT/libraries/src/Access/Access.php:540 |
Query Time: 0.74 ms After last query: 0.48 ms Query memory: 0.031 MB Memory before query: 2.614 MB Rows returned: 31
SHOW FULL COLUMNS
FROM `josed_content`
EXPLAIN not possible on query: SHOW FULL COLUMNS FROM `josed_content`
| Status | Duration |
| Opening tables | 0.35 ms |
| init | 0.01 ms |
| Filling schema table | 0.01 ms |
| checking permissions | 0.07 ms |
| Sending data | 0.04 ms |
| Removing tmp table | 0.05 ms |
| 15 | JDatabaseDriver->loadObjectList() | JROOT/libraries/joomla/database/driver/mysqli.php:448 |
| 14 | JDatabaseDriverMysqli->getTableColumns() | JROOT/libraries/src/Table/Table.php:261 |
| 13 | Joomla\CMS\Table\Table->getFields() | JROOT/libraries/src/Table/Table.php:180 |
| 12 | Joomla\CMS\Table\Table->__construct() | JROOT/libraries/src/Table/Content.php:39 |
| 11 | Joomla\CMS\Table\Content->__construct() | JROOT/libraries/src/Table/Table.php:328 |
| 10 | Joomla\CMS\Table\Table::getInstance() | JROOT/components/com_content/models/article.php:253 |
Query Time: 2.52 ms After last query: 0.87 ms Query memory: 0.005 MB Memory before query: 2.663 MB
UPDATE josed_content
SET `hits` = (`hits` + 1)
WHERE `id` = '53'
EXPLAIN not possible on query: UPDATE josed_content
WHERE `id` = '53'
| Status | Duration |
| init for update | 0.04 ms |
| Updating | 0.07 ms |
| Commit | 2.23 ms |
| Query end | 0.01 ms |
| 11 | JDatabaseDriverMysqli->execute() | JROOT/libraries/src/Table/Table.php:1264 |
| 10 | Joomla\CMS\Table\Table->hit() | JROOT/components/com_content/models/article.php:254 |
Query Time: 0.61 ms After last query: 2.09 ms Query memory: 0.023 MB Memory before query: 2.709 MB Rows returned: 1
SELECT a.id, a.asset_id, a.title, a.alias, a.introtext, a.fulltext, a.state, a.catid, a.created, a.created_by, a.created_by_alias,
CASE WHEN a.modified = '0000-00-00 00:00:00' THEN a.created ELSE a.modified END as modified, a.modified_by, a.checked_out, a.checked_out_time, a.publish_up, a.publish_down, a.images, a.urls, a.attribs, a.version, a.ordering, a.metakey, a.metadesc, a.access, a.hits, a.metadata, a.featured, a.language, a.xreference,c.title AS category_title, c.alias AS category_alias, c.access AS category_access,u.name AS author,parent.title as parent_title, parent.id as parent_id, parent.path as parent_route, parent.alias as parent_alias,ROUND(v.rating_sum / v.rating_count, 0) AS rating, v.rating_count as rating_count
FROM josed_content AS a
INNER JOIN josed_categories AS c
on c.id = a.catid
LEFT JOIN josed_users AS u
on u.id = a.created_by
ON parent.id = c.parent_id
ON a.id = v.content_id
WHERE a.id = 53
AND c.published > 0
AND (a.publish_up = '0000-00-00 00:00:00' OR a.publish_up <= '2026-06-06 18:20:54')
AND (a.publish_down = '0000-00-00 00:00:00' OR a.publish_down >= '2026-06-06 18:20:54')
AND (a.state = 1 OR a.state =2)
| 1 | SIMPLE | a | const | PRIMARY,idx_state,idx_catid | PRIMARY | 4 | const | 1 | |
| 1 | SIMPLE | c | const | PRIMARY | PRIMARY | 4 | const | 1 | |
| 1 | SIMPLE | u | const | PRIMARY | PRIMARY | 4 | const | 1 | |
| 1 | SIMPLE | parent | const | PRIMARY | PRIMARY | 4 | const | 1 | |
| 1 | SIMPLE | v | const | PRIMARY | PRIMARY | 4 | const | 0 | Unique row not found |
| Status | Duration |
| Starting | 0.13 ms |
| Opening tables | 0.06 ms |
| init | 0.05 ms |
| Optimizing | 0.03 ms |
| Statistics | 0.09 ms |
| Commit | 0.00 ms |
| Reset for next command | 0.01 ms |
| 15 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1662 |
| 14 | JDatabaseDriver->loadObject() | JROOT/components/com_content/models/article.php:151 |
| 13 | ContentModelArticle->getItem() | JROOT/libraries/src/MVC/View/HtmlView.php:425 |
| 12 | Joomla\CMS\MVC\View\HtmlView->get() | JROOT/components/com_content/views/article/view.html.php:42 |
| 11 | ContentViewArticle->display() | JROOT/libraries/src/Cache/Controller/ViewController.php:102 |
Query Time: 0.35 ms After last query: 0.97 ms Query memory: 0.022 MB Memory before query: 2.753 MB Rows returned: 0
SELECT `m`.`tag_id`,`t`.*
INNER JOIN `josed_tags` AS t
ON `m`.`tag_id` = `t`.`id`
WHERE `m`.`type_alias` = 'com_content.article'
AND `m`.`content_item_id` = 53
AND `t`.`published` = 1
AND t.access IN (1,1,5)
| Status | Duration |
| init | 0.04 ms |
| Commit | 0.00 ms |
| 13 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Helper/TagsHelper.php:454 |
| 12 | Joomla\CMS\Helper\TagsHelper->getItemTags() | JROOT/components/com_content/views/article/view.html.php:184 |
Query Time: 0.49 ms After last query: 1.68 ms Query memory: 0.027 MB Memory before query: 2.872 MB Rows returned: 2
ON (s.lft <= c.lft
AND s.rgt < c.rgt)
AND c.access IN (1,1,5)
AND c.published = 1
AND s.id = 2
ORDER BY c.lft
| 1 | SIMPLE | c | range|filter | cat_idx,idx_access,idx_left_right | idx_left_right|cat_idx | 4|207 | NULL | 2 (58%) | Using index condition; Using where; Using rowid filter |
| Status | Duration |
| init | 0.04 ms |
| Statistics | 0.08 ms |
| Sending data | 0.06 ms |
| Commit | 0.00 ms |
| 22 | JDatabaseDriverMysqli->execute() | JROOT/libraries/joomla/database/driver.php:1701 |
| 21 | JDatabaseDriver->loadObjectList() | JROOT/libraries/src/Categories/Categories.php:324 |
| 20 | Joomla\CMS\Categories\Categories->_load() | JROOT/libraries/src/Categories/Categories.php:184 |
| 19 | Joomla\CMS\Categories\Categories->get() | JROOT/administrator/components/com_fields/models/fields.php:203 |
| 18 | FieldsModelFields->getListQuery() | JROOT/libraries/src/MVC/Model/ListModel.php:140 |
| 17 | Joomla\CMS\MVC\Model\ListModel->_getListQuery() | JROOT/libraries/src/MVC/Model/ListModel.php:194 |
| 12 | JEventDispatcher->trigger() | JROOT/components/com_content/views/article/view.html.php:193 |
Query Time: 0.87 ms After last query: 0.20 ms Query memory: 0.025 MB Memory before query: 2.893 MB Rows returned: 0
FROM josed_fields AS a
ON l.lang_code = a.language
LEFT JOIN josed_users AS uc
ON uc.id=a.checked_out
ON ag.id = a.access
LEFT JOIN josed_users AS ua
ON ua.id = a.created_user_id
ON g.id = a.group_id
ON fc.field_id = a.id
AND (fc.category_id IS NULL OR fc.category_id IN (2,0))
AND a.access IN (1,1,5)
AND a.state = 1
ORDER BY a.ordering ASC
| Status | Duration |
| Opening tables | 0.05 ms |
| init | 0.04 ms |
| Preparing | 0.03 ms |
| Creating tmp table | 0.05 ms |
| Sorting result | 0.02 ms |
| Sending data | 0.25 ms |
| Creating sort index | 0.04 ms |
| Removing tmp table | 0.06 ms |
| Commit | 0.00 ms |
Query Time: 0.24 ms After last query: 0.45 ms Query memory: 0.025 MB Memory before query: 2.923 MB Rows returned: 1
SELECT option_value
LIMIT 1
| Status | Duration |
| init | 0.02 ms |
Query Time: 0.16 ms After last query: 0.03 ms Query memory: 0.024 MB Memory before query: 2.932 MB Rows returned: 1
SELECT option_value
LIMIT 1
| Status | Duration |
| init | 0.01 ms |
| Sending data | 0.00 ms |
Query Time: 0.70 ms After last query: 5.06 ms Query memory: 0.026 MB Memory before query: 3.034 MB Rows returned: 25
SELECT m.id, m.title, m.module, m.position, m.content, m.showtitle, m.params, mm.menuid
FROM josed_modules AS m
LEFT JOIN josed_modules_menu AS mm
ON mm.moduleid = m.id
LEFT JOIN josed_extensions AS e
ON e.element = m.module
AND e.client_id = m.client_id
WHERE m.published = 1
AND e.enabled = 1
AND (m.publish_up = '0000-00-00 00:00:00' OR m.publish_up <= '2026-06-06 18:20:54')
AND (m.publish_down = '0000-00-00 00:00:00' OR m.publish_down >= '2026-06-06 18:20:54')
AND m.access IN (1,1,5)
AND m.client_id = 0
AND (mm.menuid = 156 OR mm.menuid <= 0)
ORDER BY m.position, m.ordering
| 1 | SIMPLE | m | ref | PRIMARY,published,newsfeeds | published | 1 | const | 44 | Using index condition; Using where; Using filesort |
| 1 | SIMPLE | mm | ref | PRIMARY | PRIMARY | 4 | becws_dbase3.m.id | 1 | Using where; Using index |
| 1 | SIMPLE | e | ref | element_clientid,element_folder_clientid | element_clientid | 403 | becws_dbase3.m.module,const | 1 | Using index condition; Using where |
| Status | Duration |
| init | 0.03 ms |
| Creating sort index | 0.30 ms |
| Commit | 0.00 ms |
| 13 | JDatabaseDriver->loadObjectList() | Same as call in the line below. |
| 12 | call_user_func_array() | JROOT/libraries/src/Cache/Controller/CallbackController.php:173 |
| 11 | Joomla\CMS\Cache\Controller\CallbackController->get() | JROOT/libraries/src/Helper/ModuleHelper.php:441 |
| 10 | Joomla\CMS\Helper\ModuleHelper::getModuleList() | JROOT/libraries/src/Helper/ModuleHelper.php:371 |
| 9 | Joomla\CMS\Helper\ModuleHelper::load() | JROOT/libraries/src/Helper/ModuleHelper.php:87 |
| 8 | Joomla\CMS\Helper\ModuleHelper::getModules() | JROOT/libraries/src/Document/Renderer/Html/ModulesRenderer.php:45 |
| 7 | Joomla\CMS\Document\Renderer\Html\ModulesRenderer->render() | JROOT/libraries/src/Document/HtmlDocument.php:499 |
Query Time: 0.36 ms After last query: 13.71 ms Query memory: 0.023 MB Memory before query: 3.136 MB Rows returned: 0
FROM josed_bagallery_items
WHERE lightboxUrl = '/about-us'
| Status | Duration |
| init | 0.02 ms |
| Commit | 0.00 ms |
2 × SELECT option_value
FROM `josed_assets`
1 × SELECT `data`
1 × SELECT id, rules
1 × SELECT b.id
ON b.lft <= a.lft
AND b.rgt >= a.rgt
1 × SELECT `value`
1 × SELECT *
1 × SELECT *
1 × SELECT a.id, a.asset_id, a.title, a.alias, a.introtext, a.fulltext, a.state, a.catid, a.created, a.created_by, a.created_by_alias,
on c.id = a.catid
1 × SELECT `m`.`tag_id`,`t`.*
ON (s.lft <= c.lft
AND s.rgt < c.rgt)
ON ag.id = a.access
1 × SELECT m.id, m.title, m.module, m.position, m.content, m.showtitle, m.params, mm.menuid
